Hi all,
Working on a project that detects EMG data from the forearm and ultimately it will be battery powered. For the meantime I don't really want to run through a wack of batteries as it is quite costly.
Safety is the utmost concern as I will be connecting this to my arm. The commercial isolation transformers online seem to be pretty pricey, wondering if there is a more economical approach to design a system that I can use for prototyping.
It will need to be a 5V supply for some low power op amps/instrumentation amp.
Cheers!
Cheers!
