-5V from +5V supply...
Discussion in 'General Electronics Chat' started by dtvonly, Feb 20, 2013.
  1. dtvonly
    Dec 14, 2012
    43
    Hi. Using discrete components (w/o any ICs like 7905), how can I get (or reverse) a +5V into a -5V supply? Please provide circuit or link to a circuit. Thank you.
  2. MrChips
    Oct 2, 2009
    12,652
    3,461
  3. MrChips
    Oct 2, 2009
    12,652
    3,461
    If you have a restriction on using ICs, you can use a transistor oscillator driving a small transformer or a voltage doubler circuit.
  4. dtvonly
    Dec 14, 2012
    43
    Hello MrChips. One question about the devices you mentioned: what is the maximum current drive capability? The datasheets only mentioned supply current, voltages and test current of up to (only) 30mA. Is this the maximum for these devices?
  5. MrChips
    Oct 2, 2009
    12,652
    3,461
    Let's turn the question around. What current at -5V are you looking for?
  6. dtvonly
    Dec 14, 2012
    43
    Hi. I will need about 100mA. I can either buffer the output or use another inverting device, if there is one with higher output current drive.
  7. MrChips
    Oct 2, 2009
    12,652
    3,461
    100mA is substantial. You will need to build a switching supply.
  8. gootee
    Apr 24, 2007
    447
    50
  9. thatoneguy
    Feb 19, 2009
    6,357
    718
    Why can't you use ICs?
    Is this homework?
  10. t06afre
    May 11, 2009
    5,939
    1,222
