Hello guys!
I've little knowledge about electronics so I'm asking for your help .
I've build a cooling pad for my laptop using 2 80mm fans with 5v 0.3 A as specs, they are simply wired in parallel to a usb cable.
Now i have 2 questions, the fan's speed is constant when i plug to a usb wall charger (2A) and when i plug to the laptop's usb2 ports so i'm assuming the laptop's usb output is sufficient, is it risky to use the usb port with this specs?
The second question is about the speed of the fans, they're loud and i would like to regulate manually the rpm with some kind of potentiometer, i found some cheap control boards online but i'm not really sure on what i really need to buy, is a "1.8V 3V 5V 6V 12V 2A Low Voltage Motor Speed Controller PWM 1803B" okay? I need something else to protect the usb port?
Thank you for your help!
