5V Analog output to 3.3V
Discussion in 'General Electronics Chat' started by Diego Bonilla, Sep 19, 2014.
  1. Diego Bonilla
    Sep 18, 2014
    35
    Hi
    I have a Sensor Output 0-5V Analog, but mi Microcontroler (ADC) only support to 3.3V.
    How can accondition that signal?
  2. wayneh
    Sep 9, 2010
    12,394
    3,246
    Resistor voltage divider.
  3. ericgibbs
    Jan 29, 2010
    2,599
    394
    Use a 1K7 and 3k3 divider, a 5K trim pot is the easiest solution.
  4. #12
    Nov 30, 2010
    16,704
    7,354
    Many ways to skin the cat:
  5. Diego Bonilla
    Sep 18, 2014
    35
    Another solution?
  6. #12
    Nov 30, 2010
    16,704
    7,354
    4 ways isn't enough?
  7. Diego Bonilla
    Sep 18, 2014
    35
  8. Diego Bonilla
    Sep 18, 2014
    35
    Hi #12
    your propose have the Microcontroller power supply like a 3.3V.
    The Microcontroller Power supply are 5V, and the inputs only support 0-3.3V (ANALOG)
    Excuse mi ignorance and thanks for the help
  9. #12
    Nov 30, 2010
    16,704
    7,354
    Just don't connect the 3.3V to the Uc.
    Diego Bonilla likes this.
  10. Diego Bonilla
    Sep 18, 2014
    35
    Thanks a Lot #12
  11. #12
    Nov 30, 2010
    16,704
    7,354
    That's what the, "like" button is for. :)
  12. Diego Bonilla
    Sep 18, 2014
    35
    jijiji...sorry im new in this forum
  13. #12
    Nov 30, 2010
    16,704
    7,354
    No problem. That button is a new feature because all of the software for this site changed a few weeks ago.
    I just asked the important people to change it back to, "Thanks".
  14. ericgibbs
    Jan 29, 2010
    2,599
    394
    hi #12.
    Please check the placement of those two resistors, 10k and 4k7
    Eric.
    Diego Bonilla and #12 like this.
  15. #12
    Nov 30, 2010
    16,704
    7,354
    Eek! You caught me in a mistake! :eek:
    Updating now...
    Actually, I depend on peer review on this site. Everybody makes mistakes. Many eyes catch them, hopefully before they can cause much real damage. :)
  16. Papabravo
    Feb 24, 2006
    10,340
    1,850
    You could also introduce an active attenuator with a gain of (3.3/5). That way the A/D input will not load the resistive voltage divider.
  17. Diego Bonilla
    Sep 18, 2014
    35
    hi papabravo
    how is that?
  18. #12
    Nov 30, 2010
    16,704
    7,354
    Very good point. Without any data about the ADC being used, the best I can do is demonstrate the math in case the values I used are inappropriate.
  19. Diego Bonilla
    Sep 18, 2014
    35
    with Operational Amplifiers?
  20. shteii01
    Feb 19, 2010
    3,512
    512
    Voltage divider followed by a buffer?
    Sensor output goes into voltage divider, voltage divider output goes into buffer made of op amp, buffer output goes to ADC.
