5MHz and voltage
Discussion in 'General Electronics Chat' started by Board27, Mar 3, 2016.
  1. Board27
    Mar 3, 2016
    Hi all,
    this is my first post. I need to amplify the voltage level of a 5 MHz sinewave from 2.50V to 9V without translating into a squarewave.
    I was thinking at the NE5534, but i've never used one of them so far.
    Is anybody out there than can help me in this circuit?
    Regards
  2. Lestraveled
    May 19, 2014
    1,957
    1,218
    The NE5534 is not a good choice for this application. 5 MHz is just beyond the gain product-bandwidth for a gain of 3.6 that you are looking for. Talk more about the circuit. What is the load impedance. What are the power supply voltages available. Tell us what is going on.
    Oh, yea, Welcome to AAC.
  3. Board27
    Mar 3, 2016
    Hi , thanks for your aswer. Basecally it is a 5MHz (also 10MHz) TCXO exit with 50 ohm impedence, outputting at a voltage of 2.60-2.50 V as sinewave. I would like to have the same input precision of the 5MHz but exiting at 9v . Is it possible? How?
    thank you in advance for suggestions.
    regards
  4. DickCappels
    Aug 21, 2008
    2,780
    675
    If a 200 ohm output impedance is acceptable, this would be a good, simple solution:
    Here's the Google search: http://bfy.tw/4a06
    You can also do this with any other configuration that gives 4:1.
