565 pll mixer
Discussion in 'General Electronics Chat' started by vinodquilon, Jan 11, 2010.
  1. vinodquilon
    Dec 24, 2009
    234
    How I use 565 pll ic as a mixer?
  2. retched
    Dec 5, 2009
    5,201
    313
    You may not want to.
    What is your desired output? ie. How have you set up your signals prior to needing mixing? And what levels are you trying to ultimately achieve?
  3. retched
    Dec 5, 2009
    5,201
    313
    This may help. This PDF does well explaining the part and contains a schematic.
    However, depending on your application, you may want to consider a less ..obsolete.. ic.
    www2.arrl.org/tis/info/pdf/0809071.pdf
