555
Discussion in 'The Projects Forum' started by ht systems, Aug 21, 2011.
  1. ht systems
    Aug 2, 2011
    71
    can i use an ac voltage as an input to 555 circuit ?
  2. #12
    Nov 30, 2010
    16,660
    7,305
    yes
  3. ht systems
    Aug 2, 2011
    71
    thank you , i guess i have to try it
  4. bertus
    Administrator
    Apr 5, 2008
    15,796
    2,384
    The powersupply of the 555 MUST be DC.
    What input do you mean?
    The trigger input may NOT go negative and above the DC voltage of the powersupply.
    Bertus
  5. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Well, no - it can't use AC directly as an input, as AC implies that the signal goes above and below the 0v reference; the negative voltage would burn up the 555 timer.
    It might use rippled DC input, as long as the rippled DC did not exceed the limits of the timers' power supply rails.
    Rippled DC can resemble AC (as a sine wave), but isn't centered around the 0v reference.
  6. #12
    Nov 30, 2010
    16,660
    7,305
    Good point, wookie. I missed that. Or did I assume ht knew that? It's so hard to guess the intellectual level of a person when you've only seen him make one sentence.
  7. Wendy
    Mar 24, 2008
    20,772
    2,540
    Always assume the worst. And ask for a schematic.
  8. Bernard
    Aug 7, 2008
    4,231
    414
    Could use clipping diodes to VCC & GND with current limiting, also capacitive couple input.
  9. JingleJoe
    Member
    Jul 23, 2011
    185
    10
    Sometimes I feel like I am the only person who can see this thread.
