555 weird one shot question
Discussion in 'The Projects Forum' started by Gate5, May 29, 2016.
  1. Gate5
    May 29, 2016
    Ok hi all I won't might light to stay on as long as the switch is on but when switch is off then start the one shot timer to turn off light in like 2 min could someone like point me to a diagram of 555 pins for that thanks
  2. tracecom
    Apr 16, 2010
    3,878
    1,396
    Ok, hi all. I want my light to stay on as long as the switch is on but when switch is off, then start the one shot timer to turn off light in approximately 2 minutes. Could someone point me to a schematic diagram of a 555 circuit that does that? Thanks.
    Is that what you need?
  3. Dodgydave
    Jun 22, 2012
    5,142
    768
  4. Gate5
    May 29, 2016
    Ok want to turn on head lights when ignition switch is on want 555 timer to control 2 min delay when ign switch is off make my old truck like my new car the problem is the 555 timer is so versatile (witch is good) it's acting different then what I want please note I'm not great at electronics just really light to play with them thanks
  5. Gate5
    May 29, 2016
  6. Dodgydave
    Jun 22, 2012
    5,142
    768
    If you need to start the timer when the ignition is off, you will need a npn transistor to pull the trigger pin low.
  7. Gate5
    May 29, 2016
    Thank you Dodgydave sorry for late reply had company
