555 voltage drop
Discussion in 'The Projects Forum' started by GuruMeditation, Jan 9, 2016.
  1. GuruMeditation
    Jan 9, 2016
    9
    Hi All,
    I've done a search and can't see a specific answer to my query so here goes... :)
    I'm newish to electronics and am experimenting with a 555 timer IC in astable mode and powered by a 9v battery. I'm trying to calculate the ratings of the resistors needed for the LEDs it will be flashing but the output voltage at pin 3 seems wrong. I'm given to believe the voltage drop should be around 1.7v but when I took a reading with my multimeter while it was high, it was showing 8.6v. I then changed out the IC for another and that was showing 8.7v.
    That's not right, is it? Any advice please?
    Thanks, Tony
  2. sailorjoe
    Member
    Jun 4, 2013
    361
    63
    Yeah, it's right because you're using a 9 v battery. Why are you given to believe it should be 1.7 v?
    GuruMeditation likes this.
  3. Colin55
    Member
    Aug 27, 2015
    205
    21
    What voltage are you reading?
  4. GuruMeditation
    Jan 9, 2016
    9
    Good question! I can't remember exactly where I first read that. Maybe I misunderstood something :oops:
  5. GuruMeditation
    Jan 9, 2016
    9
    8.6 - 8.7v
  6. Colin55
    Member
    Aug 27, 2015
    205
    21
    No. Where on the circuit are you taking the measurement
  7. GuruMeditation
    Jan 9, 2016
    9
    Oh sorry! From between pin 3 and ground.
  8. Papabravo
    Feb 24, 2006
    10,340
    1,850
    IIRC the output on pin 3 should swing between Vcc minus a couple of tenths and GND. Sounds normal to me.
  9. GuruMeditation
    Jan 9, 2016
    9
    Ok guys, thank you very much for your quick replies! I got a voltage I can work from now :cool:
    Tony
  10. wayneh
    Sep 9, 2010
    12,403
    3,251
    FWIW, I believe some flavors of the 555 cannot get the output that close to Vcc, and you might have seen the 1.7V value as the max drop off of Vcc, for instance 7.3V output from a 9V source.
  11. GuruMeditation
    Jan 9, 2016
    9
    Very possibly. If I build any other projects using a 555 I'll power it up and check before proceeding with any component calculations.
  12. GopherT
    Nov 23, 2012
    6,330
    4,080
    The datasheet says that high level output is at least 13V on a 15V supply (lists 13.3 as typical). So there is your 1.7 V. Same for 5v supply. 3V minimum and 3.3V typical.
    http://www.ti.com/lit/ds/symlink/ne555.pdf
  13. GuruMeditation
    Jan 9, 2016
    9
    Would it make a difference that the one's I'm using are ST & not TI?
  14. GopherT
    Nov 23, 2012
    6,330
    4,080
    Check the datasheet is my typical answer. Next time google manufacurer's name, apart number and the word datasheet.
    Looks like it drops off more with more current. It doesn't show voltage with no load (0 amp current on pin 3).
    The sT datasheets are terrible in general. They show 200 and 100 mA load data. Goes down to 12.7 at 200 mA load (from 15 v). Otherwise typical values mirror TI part data. It is likely near 15 v at no load.
  15. GuruMeditation
    Jan 9, 2016
    9
    Thanks GopherT...same though occurred to me...found the datasheet but not read one before...ummm....:rolleyes:
  16. GopherT
    Nov 23, 2012
    6,330
    4,080
    Here is what you are looking for (high output voltage.
  17. Colin55
    Member
    Aug 27, 2015
    205
    21
    Yes, you lose about 3v when driving a load from pin3. The 555 is a very poor chip and we only use it because it costs 8 cents.
    You can parallel pin 7 with 3 to gain about 0.8v.
  18. GuruMeditation
    Jan 9, 2016
    9
    Thank you :cool:
  19. wayneh
    Sep 9, 2010
    12,403
    3,251
    Them's fightin' words 'round here! :D
    Sinus23 and GuruMeditation like this.
