Hi folks,
Relatively new here and this is my first post so please correct me if I've done anything wrong.
Looking for a bit of a sanity check here since its been oh so long since I've done any serious design. I am looking for advice/critique of a simple 555/transistor circuit I'm working on for a laser optics application. In a nutshell, the requirements are if the user wants to open the shutter to enable the laser on the optics table, there is an approximate 10s delay that sounds an alarm, and then the shutter opens. So, I used a 556 to create the 10s delay, and the other half of it to invert the output since the Bogen tone generator is active low. See http://www.bogen.com/products/pdfs/specialelectronicspdfs/TG4Cm.pdf.
Once the 10s is over, I use a 555 to generate a 0.25s pulse to open the shutter. Pretty easy so far but the shutter is a 24V device not 12V, so I put a 2N3904 in there to drive it. That's where I'm a bit shaky. I'm not sure if my very simple setup is correct. It works, but is it correct or just 'good enough'?
The shutter is a Lasermet LS-10, 24V. http://www.lasermet.com/laser-beam-shutters.php Since they sell a complete laser safety system I have not been able to get a lot of good technical information, but I have a question into them if the shutter should be a inductive load or not or even how much current or power it needs.
From their literature is the following:
DB-9 pinout
1 +12V DC power to shutter 2 0V
3 Remote open input
4 Not Used (Internally connected to pin 1)
5 Open status output
6 Closed status output
7 - 9 Optional electrical Interlock option - see below.
5 and 6 give the status of the shutter,
If using remote control with a switched 12V supply connect the switched +12V supply + to pins 1 and 3 and to pin 2. The shutter will open immediately the supply is turned on.
If using remote pushbuttons to control the shutter use a normally-closed button in series with the supply for the Close function, and a normally-open pushbutton between pins 1 and 3 for the Open pushbutton. Both switches need only switch for approximately 0.25 s to close or open the shutter.
Note that the literature says 12V but there is a note saying it still applies to the 24V version.
I'm attaching my schematic, and have two questions. First, and most importantly, is the 2N3904 part to the shutter correct? (BTW, I'm not sure if the resistor is a 10K but I'm not there so I can't double check. I will though.) That's what I really need help with.
Secondly, and more of an incidental/curiousity, can I replace the second half of the 556, which is inverting the first half, with a 2N3906 to invert the signal? That way I only need the one chip. I know, two transistors and one chip vs. one transistor and two chips so there is no real savings. Like I said, more of a curiousity.
If I need to supply any more information or am unclear about anything, please let me know and I'll clear it up ASAP.
Thanks all for your help.
DB-9 pinout
3 Remote open input
