555 Timer
Discussion in 'The Projects Forum' started by GRNDPNDR, Mar 20, 2014.
  1. GRNDPNDR
    Mar 1, 2012
    449
    7
    I just built this circuit following directions from one of our labs when I was in school, and now that it's assembled it will flash the LED, but the pot is useless.
    I can even remove the pot from the circuit and it will still flash.
    Where did I go wrong here??
    I followed the directions instead of the schematic, but I just checked it and I'm fairly sure it's all wired right.
    Here is a picture of my breadboard, and the lab I followed....which is a bit confusing at points I think.
  2. Dodgydave
    Jun 22, 2012
    5,167
    777
    Remove the blue jumper 25, on the left side of the chip, as it is shorting out the pot.
  3. ericgibbs
    Jan 29, 2010
    2,604
    396
    Also pin 2 and 6 and not linked and pin 4 is not connected.
    EDIT:
    Woops..See that pins 2 and 6 are linked across the top!
  4. tracecom
    Apr 16, 2010
    3,879
    1,396
    You have both sides of the VR connected to pins 6&2. In addition, pin 4 should be tied high, and although the schematic doesn't show it, there should be a .1uF cap from pin 1 to pin 8.
  5. GRNDPNDR
    Mar 1, 2012
    449
    7
    The instructions say to do this.... but I remember some of them weren't always correct, not sure if this was one of them.
    Right, I missed the pin 4 connection, so I'll hook that to Vcc.
    The VR?
  6. GRNDPNDR
    Mar 1, 2012
    449
    7
    Got it working. Put power to pin 4, and removed the jumper on the pot....which I'm still confused as to why they said it should be there.
    Also forgot about that handy power supply I bought a couple of weeks ago.
  7. ericgibbs
    Jan 29, 2010
    2,604
    396
    hi,
    It may appear to be working, but not in the way the design specifies.
    That link across the pot is required, its in series with the 4k7 and the 10uF cap.
    If the link is across the top two pins of the pot, the adjustment will be CW and if across the lower two pins the adjustment will CW.
  8. nerdegutta
    Dec 15, 2009
    2,572
    807
    OK, so what is the difference?
  9. ericgibbs
    Jan 29, 2010
    2,604
    396
    The difference is that user may want to increase the 555 period as he turns the pot clockwise or have the option to decrease the period if he turns it clockwise.
    I am making him aware of the pot sense options, nothing more than that.
  10. nerdegutta
    Dec 15, 2009
    2,572
    807
    OK, got a bit confused since both directions where clockwise. Thanks!
  11. ericgibbs
    Jan 29, 2010
    2,604
    396
    hi ,np.
    I suppose its because we have got used to having the controlled variable increase as we turn a control knob clockwise eg; audio volume controls.
    E.:)
  12. GRNDPNDR
    Mar 1, 2012
    449
    7
    If I connect that jumper across pins 1 and 2 of the pot, the light just flashes at maximum speed because it's bypassing the pot.
    so I really don't understand the purpose of that jumper
  13. tracecom
    Apr 16, 2010
    3,879
    1,396
    The problem is that you have both sides of the variable resistor connected to pins 6 and 2. (Seems like I already said that.)
  14. ericgibbs
    Jan 29, 2010
    2,604
    396
    If you look at my post #7 layout image, the 'extra' link has been removed.
  15. GRNDPNDR
    Mar 1, 2012
    449
    7
    Didn't know what you meant by 'VR' then forgot.
    The schematic shows pin 2 and 6 connected to the pin 3 on the pot.
    why would they have us build this circuit like this ?!?!?
    I'll make those changes in a bit and see what happens.
  16. GRNDPNDR
    Mar 1, 2012
    449
    7
    so I see now what I did, connecting pins 2 and 6 to the pot such as I did, but I didn't see the error until I looked at the two pics side by side.
    not really sure why or how I did that....
  17. GRNDPNDR
    Mar 1, 2012
    449
    7
    nevermind.
  18. ericgibbs
    Jan 29, 2010
    2,604
    396
    Is it now working as you expect.?:)
    E
  19. GRNDPNDR
    Mar 1, 2012
    449
    7
    Yes, I powered it up at first and the chip got hot.....because I put the power supply in backwards.
    But, it still works now that I've put the supply in correctly.
    Pretty hearty devices these 555's
    I've been trying to find a pre-made 555 timer that would plug into a breadboard like this little power supply/regulator but haven't found one yet. Well the one I did find, I didn't really like.
  20. ericgibbs
    Jan 29, 2010
    2,604
    396
