555 Timer
Discussion in 'General Electronics Chat' started by Bertus2, Mar 22, 2009.
  1. Bertus2
    Mar 20, 2009
    5
    Hi
    Is there a way of generating a fixed frequency signal, but with a variable dutycycle, with a single LM555. The Dutycycle must be variable from about 10 - 90% .
  2. Wendy
    Mar 24, 2008
    20,772
    2,540
    You betcha, it is easy as toast.
    Ignore and remove R2, it is bogus. There is another website that came up with it, when/if I find them I'll post the site.
    Here it is:
    http://www.dprg.org/tutorials/2005-11a/index.html
  3. Bertus2
    Mar 20, 2009
    5
    What do you do with pin7?
  4. hgmjr
    Jan 28, 2005
    9,030
    214
    Pin 7 is not required since the output square wave on Pin 3 is charging and discharging the capacitor through the diode and resistor network.
    hgmjr
  5. Bertus2
    Mar 20, 2009
    5
    Thanks. I'll give it a go.
    Bertus2
  6. Metalfan1185
    Sep 12, 2008
    146
    ok, just wondering...
    is it possible to do the same, but have a variable frequency and the fixed duty cycle?
  7. Wendy
    Mar 24, 2008
    20,772
    2,540
    That is a subject for another thread, hijacking is discouraged.
    It could be done, but not with a single 555.
  8. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Actually Bill, if R2 is 1/10 the value of R1, it will limit the PWM range to what the O.P. requested.
    I suggest that R2 is not bogus; it limits the peak charge/discharge current through the diodes to/from C if R1 is at one end or the other.
  9. thatoneguy
    Feb 19, 2009
    6,357
    718
    The schematic shows R2 as variable though, so it too can be zero Ω. The way it's drawn doesn't make it stick out as a pot right away. It should be a small fixed value, not variable.
  10. Wendy
    Mar 24, 2008
    20,772
    2,540
    It was a recycled brain fart, and we all know how those smell. The base circuit is a variation of this, but the diodes force different charge/discharge paths. Since the resistance always adds up the same, the frequency shouldn't change much.
  11. thatoneguy
    Feb 19, 2009
    6,357
    718
    That's an excellent 555 tutorial, cool pitchers too!
