Hi guys,
I'm trying to make a small timer circuit for the indicators on my motorbike. I've made the circuit up on a breadboard and it works perfectly. The only issue I have now is that the trigger has to be low to start the timer but high again for it to turn off. With this being the case I've been using a N/C pushbutton to interrupt the voltage to the trigger.
I have a N/O pushbutton on my motorbike and would like to use a positive or negative pulse to set off this circuit as an Off-delay timer (pulse, on for 10 sec and then switch back to off as the relaxed state).
I don't want to use a bulky relay and the N/C contact on it to do this and I can't change the switch to a N/C.
Is there a small component I can add to the attached circuit to do what I want?
Regards,
Mick
Regards,
Mick
