I'm a little perplexed...I've just been playing with some 555 timer circuits, pretty neat and pretty simple. I then tried making a cct for. 7 minute monostable timer..for a bathroom heater - one push eq 7 mins run time then off till next push of momentary switch.
So I started making the RC combos for this.. it makes sense to use a large cap, say 470uF etc so as to keep resistance down. But there in lies the problem, to go for a electrolytic to get the larger values you get like 20% tolerance which changes the time quite a bit. If I go for a tantalum which might be 10uF means a huge resistance value, even with a 1% tolerance R that can also lead to a very un precise timer.
So what is one to do? How can you make a 555 timer for longer timing periods - ie 10-30 minutes and overcome these issues.
So putting it in contrast I then look at the economies of scale.. I can buy a PICAXE chip for about $9 which requires bugger all supporting components and is quite accurate and infinately more flexible... Why would one not scrap the 555 idea and just go for a PICAXE circuit(assuming one can program picaxe, as I can)..
Appreciate all ideas on all points!
Thanks..
Thanks..
