555 timer VCO
Discussion in 'The Projects Forum' started by suzuki, Nov 25, 2011.
Thread Status:
Not open for further replies.
  1. suzuki
    Aug 10, 2011
    119
    hi,
    i am trying to use a 555 timer to build a voltage controlled oscillator. I am finding that by increasing the control voltage i send to the 555, the lower the frequency, so i do know how to generate for example, 50kHz or 500kHz. this seems to be verified after doing a couple google searches.
    My problem is how can i increase the range of frequencies that the 555 can output? for example, if i can generate 50kHz, the range of frequencies is from 50kHz to 100kHz, or if i generate 500kHz, the range is from 500k to 550k. I have seen the formula
    f = 1.44/(C*R)
    which i believe gives the center frequency, but i dont really know what parameters i can change to increase the range of possible frequencies. e.g. i want my 555 timer to be able to output between 50kHz and 500kHz, which i suppose means increasing the bandwidth of my vco?.
    thx
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    You won't be able to get that wide of a bandwidth. You might increase or decrease the frequency by 100%, but not 1000%.
    That's because pin 5, CTRL only gives access to the threshold of the internal voltage divider, not the trigger.
  3. MrChips
    Oct 2, 2009
    12,652
    3,460
    Try an XR2209.
  4. suzuki
    Aug 10, 2011
    119
    Hmm ok, could you give me more details about this?. I would still be interested to know how i could get 100% of the frequency. I.e. if my center was 200kHz then how I would be able to get +/- 200kHz or 0 to 400k.
    I was finding that i could only get about 20% of bandwidth ie for 100k about 20kHz of possible range.
    Thanks for all replies
  5. Yako
    Nov 24, 2011
    245
    Yeah 2/3 of VCC.
    The duty cycle for an NE555-based VCO is terrible too.
    Very, very narrow. Try interfacing it to some other parts.
  6. Wendy
    Mar 24, 2008
    20,772
    2,540
    Actually the duty cycle problem can be solved by using pin 5 as a VCO and the 555 Hysteretic Oscillator, though it would work better with a CMOS 555.
  7. Yako
    Nov 24, 2011
    245
    I am going to take an educated guess and say that you've read most of Forrest M. Mims III 's Radio Shack books.
  8. Wendy
    Mar 24, 2008
    20,772
    2,540
    Yep, then gave them away while I was in college to a high school student. He visits this site occasionally.
    Forrest M. Mims III
  9. suzuki
    Aug 10, 2011
    119
    does this mean that the CTRL voltage can only go up to 2/3 of Vcc? im not sure if this is a problem, you would just get a broader step between frequencies. i.e instead of each volt going up 10kHz, each control voltage step goes up 50kHz...so less resolution, but a more broad range is still achievable, i think.
    still awaiting sgtwookie's response here
  10. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    You can pull pin 5 nearly to Vcc, but as you do so, the time will be very susceptible to triggering by noise on the power rails.
    You can also pull pin 5 down to ground. [eta] When pin 5 is at ground, the ON duty cycle % will be the lowest, but the output frequency starts decreasing again once you get below a certain point; somewhere around 1/10th Vcc, but it depends on your Vcc and the particular timer as well.
    Whatever voltage pin 5 is set to (threshold), the trigger will be 1/2 of that voltage.
    The duty cycle will change very significantly as the CTRL input is varied from nearly Vcc down to ground.
    In a bjt 555, there are three 5k resistors in series from Vcc to GND. The threshold and pin 5 are connected to the upper junction. The trigger is connected to the lower junction; and there is no external access to this junction.
    If you want a frequency of zero Hz, turn the power off, short pins 2 & 6 to ground, short pins 2 & 6 to Vcc, or short pin 4 to ground, as those are about the only ways you'll get there.
  11. Bernard
    Aug 7, 2008
    4,244
    423
    The 4046, phase -loched loop, contains a wideband,self contained VCO, requiring 2 ext Rs & one C.
  12. HF94
    Feb 10, 2014
    9
    I really hope there's a complete theory with right formula to control the frequency range and duty cycle for this 555 VCO :(
  13. Wendy
    Mar 24, 2008
    20,772
    2,540
    Necroposting and Hijacking are not allowed on AAC.
    Necroposting, posting on a long dead thread, where the TS has moved on and no body care.
    Hijacking, trying to take over someone elses thread. A thread belongs to the one who started it, so feel free to start your own.
Thread Status:
