0.01µF is 10nF
However, it's not critical, so use 0.1µF or 0.01µF, whatever you've got.
The BC547 can be replaced by just about any small signal NPN. a 2N3904 is quite fine.
OK, then you have a couple of circuits to choose from.I only said 555 because I figured it needed some type of timed relay and a 555 timer is cheap.
100nF is 0.1µFI wanted to know if a 100nf is == 0.01 uf.
and if BC547 == 2N3904
I know nothing about transistors so I tried matching everything up as close as I could. emitter-base is 6v and max volts is 60v, those were the same I though they'd work the same. Can I get a confirmation?
0.01µF is 10nF
