It depends on how good your hearing is, and how loud the earphone is.How far would the sound travel from an earphone?
I'm not Bill, but electrically, C2 is where it should be in both schematics.also, @Bill
on your schematic it show C2 between the switch and the board, but on your circuit board image it isn't. Do I follow the image, or the schematic?
thanks
so if I followed the image part, it'd work. To me, that's the easiest to understand. Thanks!It depends on how good your hearing is, and how loud the earphone is.
The physical layout has to be different from the schematic due to the way the physical parts are made. Schematics are drawn to be as easily understood as possible.
Thread starter | Similar threads | Forum | Replies | Date |
Timer-relay setup for reversing DC motor polarity | General Electronics Chat | 4 | ||
M | Timer switch disco | Analog & Mixed-Signal Design | 5 | |
U | A circuit for a continuous running timer | General Electronics Chat | 5 | |
R | digital timer thc15a wiring | General Electronics Chat | 15 | |
Single tone buzzer with 555 timer | Homework Help | 24 |
by Duane Benson
by Duane Benson
by Aaron Carman
by Duane Benson
