555 timer,relay with dc motor(12V)
vigneshsan
Joined Aug 5, 2012
I wanted to make a dc motor run for a fixed duration . So I employed a 555 timer in monostable mode and fed the pin 3 output to a relay com terminal and then i connected the motor to the relay .Its a 12v relay and a 12v dc motor.The 555 is perfectly working in monostable mode but the problem is i can't drive the motor on coupling the circuit with the motor by means of the relay.....so i need a solution for this.... secondly can i directly feed the pin3 output to the dc by suitably amplifying the output , sufficient to drive the motor
#12
Joined Nov 30, 2010
18,224
You're having trouble connecting the motor to the relay terminals?
A drawing of your circuit would be a lot of help. Can you post a drawing?
Bernard
Joined Aug 7, 2008
5,784
Partial schematic of 555 driving a relay is shown so that we can compare notes. Without D1, D2, 555 will most likley mis fire, resetting on trigger & possible damage to 555.
vigneshsan
Joined Aug 5, 2012
thank you for your suggestion . i will try out with this and check .....And the following attachment shows the way i connected the circuit
