555 timer question
lokeycmos
Joined Apr 3, 2009
431
i built the attached circuit(everything to the left of pin 3) no transistor or FET. this is for a demonstration im doing on frequency and duty cycle on a scope(for my youtube channel) which 10k pot is for frequency and which is for duty cycle? i hooked up my frequency and duty cycle meter to the output of pin 3. it seems like both pots adjust both the frequency and the duty cycle. thank you in advance!
DerStrom8
Joined Feb 20, 2011
2,390
The one on top is for adjusting the frequency, and the one between pin 7 and 2 is for adjusting duty cycle, I believe. However, I wouldn't run the circuit the way it is set up now with an inductive load. you have no back emf protection and it could damage your chip. As long as you're only using it to show how PWM works on a scope, though, you should be okay.
Good luck!
Regards,
Der Strom
lokeycmos
Joined Apr 3, 2009
431
Good luck!
Regards,
Der Strom
is there a reason that both pots adust both frequency and duty cycle?
DerStrom8
Joined Feb 20, 2011
2,390
It's difficult not to with only a single 555. Adjusting the frequency will usually change the duty cycle slightly, and vise versa. You can usually get around this by either using two 555 timers, or a 555 timer and a 393 op amp. If you only have one 555, I would recommend this circuit:
It's not perfect, but it works better than the one you have.
If you find a 393 (or a 358--they have the same pinout and function), you can make this circuit here:
I've used that one on many occasions and it works like a charm. Frequency and duty cycle adjustment is completely independent of one another, and I must say, this is one of my favorite PWM circuits.
I hope this helps!
Regards
lokeycmos
Joined Apr 3, 2009
431
I hope this helps!
Regards
what are the values of parts in your eagle cad schematic?
DerStrom8
Joined Feb 20, 2011
2,390
Oops, sorry. I guess I forgot to include the parts list.
i would like to build the circuit with the 393 opamp, but i dont have one available. could i substitute a 741 or TL072? i found the circuit with values here:
http://www.rmcybernetics.com/projects/DIY_Devices/homemade_pulse_controller.htm
i also heard you can use 2 555's to have independant control, but i cant seem to find a schematic for this. trying to keep the parts to a minimum.
Yes, RMCybernetics is where I got the design for the 393 and 555 circuit. I believe a 741 would work, but it may not work as well as a 393. It is older, and I believe it is less precise and efficient. Also, the pinout would be different from the 393, so you would have to look at the datasheet to find the right pins to use.
is there any common household electronics that would have a 393 in them?
I have found many 358s on computer motherboards, video came console boards, TV circuit boards, and several others. They also shouldn't cost very much--you can probably buy them online for very cheap.
Any equivalent of the 393 or 358 should work fine. I once found a BA6993. I googled the part number, and it was almost exactly the same as the 393. It had the same pinout and everything, and I was able to substitute it in for my circuit that required the 393.
lokeycmos
Joined Apr 3, 2009
431
i was able to find an AX358 in an old computer power supply. i built this circuit but it seems unstable. i left out the diode and mosfet. its connected directly to frequency meter and oscilloscope.
the output seems to cut in and out. its almost like a loose connection, but when i put my hand near it to wiggle a wire then it cuts back on before i even touch it. couple questions: is the AX358 sutible for this? also, where does the output from the 555 come from? i always thought the output was pin 3. its not connected to anything. the AX358 has 2 opamps in it, do the unused pins have to be grouned out to function correctly?
DerStrom8
Joined Feb 20, 2011
2,390
Yes, you can use the 339. The 339 is only a quad version of the 393. Watch the pin numbers, though. They'll definitely be different.
The AX358 is a CMOS operational amplifier. Being CMOS, it requires very little current, so any stray capacitance will affect the output. Try to find a non-CMOS version, or use the 339. It should work a lot better, and will not be as sensitive to nearby body parts (like your hand).
Regards
Ron H
Joined Apr 14, 2005
7,063
After looking at the specs of the AX358, I think it is an LM358 clone, which is bipolar technology, not CMOS. If it is sensitive to hand proximity, it is almost certainly oscillating. Do you have a 100nF cap from Vcc to ground, with short leads, connected as close to the IC pins as possible? if not, that is the likely cause of your oscillation.
The 358 is an op amp. It will work as a comparator, but it is much slower than an LM393 or an LM339. Keep in mind that 393s and 339s need output pullup resistors, because they have open collector outputs.
Also - you need to connect the +input of the unused op amp to ground, and the output to the -input. Otherwise, it may oscillate, or otherwise wreak havoc with the section you are using.
