it was only 2 days... and it was a TL071...Imagine crying over a circuit for two weeks, figuring out why that darn 555 won't work, and then realising it's a PIC!
Use the schematic off the 555 Hysteretic Oscillator to alternate LEDs, it is a very standardized design.Basic Multivibrator
This circuit has multiple experiments, here and here for example.
C2 is optional, and can be eliminated if the power supply is quiet.
Conventional 555 Characteristics
Good
- Excellent stability over power supply range.
- Can drive LEDs without affecting performance.
- Can be adjusted from 50.1% to 99% duty cycle.
Bad
- R1 is across the power supply when output is low, drawing unnecessary power.
- If R1 is too low IC will be damaged.
Basic Multivibrator with Diode
Good
- Can cover a wide range of duty cycles, 1% to 99%.
Bad
- The diode makes the math fairly imprecise.
- Duty Cycle and Frequency will drift with power supply voltage variations (also due to the diode).
- If R1 is too low the IC will be damaged.
thanks Sgt...this sounds easy enough...basically if im using a 9v supply i would want a 1k resistor between pin7 and (+)..right?....and this might sound a bit slow..but..do all IC's generate sound tones to drive the led or whatever it is that may be hooked up?..and what qualifies as a quiet power supply...thanksYou should always have at least 100 Ohms per volt of Vcc between pin 7 and +V; if you were using a 12v supply, you'd use at least 1.2k Ohms.
Sure, that would work. 9*100 = 900 Ohms. 910 Ohms is the closest standard value. Since 1k Ohms is greater than 900 Ohms, it would be OK.thanks Sgt...this sounds easy enough...basically if im using a 9v supply i would want a 1k resistor between pin7 and (+)..right?....
I'm not quite certain what you're asking here.and this might sound a bit slow..but..do all IC's generate sound tones to drive the led or whatever it is that may be hooked up?
It's more or less the ripple voltage on the output of the supply...and what qualifies as a quiet power supply...thanks
This isn't right. DISCH should be hooked up between the 2 resistors, like in Bill_Marsden's post.Try laying it out as per this diagram.
I hadn't looked at your breadboard layout before, but Gage's response prompted me to do so.It looks okay to me - but I think it's quite confusing.
It's far easier - in this case - to have one positive and one negative rail.
Also, some people might wrap LED and resistor legs together, but that's something I really hate. Why bother with the breadboard if you're going to wrap components together? Just use the holes.
The timers you tested with Sparky49's layout will certainly have pin 7 burned up. They might be salvageable if a different circuit layout is used, but not for this particular circuit.thanks again everyone....so i take it my timers are fried...
More is good.good thing just got a couple more..considering ill be stuck at home all night...
Yes, it is. What you showed on your breadboard in the photo should have worked unless pin 4 was staying low for some reason; maybe you had accidentally shorted the resistor leads together, shorting pin 7 to pin 8 and thus Vcc.Sgt. Wookie..is the layout you have provided a working revision of what i had originally??...
No!! Not unless you want to burn up more timers!and so i understand for future reference...does pin 7 wire into the Vcc pin8?
+ to pin 7 with a 10k, then pin 7 to pin 6 with a 100k....or do i just wire a resistor from (+) to pin7 then from pin7 to pin6 with another resistor??...i think i confused myself...as alwaysthaks...
Great! It's always nice when you're winning...thanks Sgt. Wookie...it works!...
OK, you sure can try them with the 1st breadboard layout that I posted; but if that doesn't work, go to the 2nd breadboard layout.I didnt try the old ones yet..thats next...
Like a high-pressure sodium lamp? That's a bit odd... well, a couple of things that are missing from your circuit as it is right now is an 0.1uF cap across pins 1 and 8, and another larger cap (1uF or larger) also across pins 1 and 8. I didn't have you put them on as you were having so much trouble with just the basic circuit. However, if you look in National Semiconductor's datasheet for the LM555, you will see that they recommend both 0.1uF and 1uF or larger caps across the power pins.a few notes though...when the light would go out it wouldn't flash back on cleanly...it reminded me of how an HPS light fires up...if that makes sense...
NO! .... Ahhh ... well, ok - go ahead.and another thing..if i may...
Yes. It's a function of the resistance and capacitance.on a capacitor..the lower the number μF the faster the flash rate the light would perform?...
That's the maximum voltage that you can put across the terminals. If you try to exceed that voltage, the "leakage current" will become excessive; the capacitor acts almost like a Zener diode and "clamps" the voltage at the capacitor's voltage rating. This isn't good for the capacitor; it's not designed to do that. The capacitor will heat up, and if it gets hot enough, it will rupture forcefully, spewing aluminum confetti everywhere and smelling like a stink bomb. It's a lot less fun than it sounds like.and what exactly does the voltage number on the capacitor indicate??... thanks
They may very well be damaged (I tried that when trying to build a plasma speaker, which is essentially the same circuit... desperation is a funny thing), they only have a very thin aluminum oxide coating inside that prevents current flow, all it takes is 1.5 volts the wrong way to destroy that, and had you left them on too long they may very well have exploded, they're essentially a short, so you're dissipating energy inside a sealed metal capsule full of saltwater(that's an oversimplification), which will get hot... then boili might have blown my capacitors...when i was trying to figure out what the problem was originally i was taking my capacitors out and shoving them in the bread both ways....lol...had no idea...
Thread starter | Similar threads | Forum | Replies | Date |
H | 555 timer pulse width problem | Analog & Mixed-Signal Design | 13 | |
P | Problem with Ramp signal Generator using IC 555 | Homework Help | 5 | |
J | NE555 Timer circuit Problem | General Electronics Chat | 16 | |
Problem with high and low of 555 astable timer | Digital Design | 30 | ||
E | LP0701 P channel FET drive problem from ICM7242 timer | Digital Design | 88 |
by Aaron Carman
by Aaron Carman
by Duane Benson
