555 Timer Police Lights Issue
Discussion in 'The Projects Forum' started by (OCP)RoboCop, Oct 27, 2012.
  1. (OCP)RoboCop
    Oct 27, 2012
    8
    Hello I am new to the forum but after looking around at other breadboard/electronic related forums this one stood out to me.
    I am brand new to breadboard'ing and I bought a setup the other day to giving it a try and start to learn about how it all works and get a hold of the fundamentals of electronics.
    In any even I started out by trying the 555-timer-circuits.com Police Lights circuit and when I was finished and hooked the 9V up to the breadboard I got one flash from the red LED's then they stayed on at a dim level and the blue lights don't come on at all.
    I double checked the wiring and had a couple things off that are now fixed and tested all 4 LED's and they are working. I am suspecting I using the wrong resistor somewhere although my double check puts me in the clear.
    Here is the schematic of what I am trying to do -
    Here is my breadboard -
    And here is the link to a video and other info on the project -
    http://www.555-timer-circuits.com/police-lights.html
    Any help will be greatly appreciated
  2. paulktreg
    Distinguished Member
    Jun 2, 2008
    622
    124
    I don't see a supply to your 4017? Pin 8 to 0V and pin 16 to 9V.
    ... and pin 14 looks like it's connected to 0V and the 555?
  3. (OCP)RoboCop
    Oct 27, 2012
    8
    You must excuse me I am quite the novice, so do I have to add a wire or just move an existing one?
  4. kc5tpa
    Member
    Sep 21, 2012
    48
    One problem is Pin 1 (555) to Pin 8 (4017) - 0V needs to be done. You have Pin 1 (555) to Pin 7 (4017)
  5. kc5tpa
    Member
    Sep 21, 2012
    48
    As far as the rest of the circuit is is hard to tell how the passive components are connected, as you can't really see the pins locations.
  6. kc5tpa
    Member
    Sep 21, 2012
    48
    Pin 16 needs to be on the 9V, as Paul pointed out.
  7. (OCP)RoboCop
    Oct 27, 2012
    8
    Are these two pictures correct pin layouts of each chip?
    555 -
    4017B -
    Sorry for the small pics that's all I could find for the time being
    On the 4017 what number do you follow? The number in the black square or the number right to the side of the black square?
    Thanks again for the help guys
  8. kc5tpa
    Member
    Sep 21, 2012
    48
    Another way to know, Pin 1 is by the 'dimple'
    Counting down from that pin you have 1-4 (on the 555) and 1-8 (on the 4017) directly across from pin 4 and 8 are 5 and 9 then count back up the other side. For these types of 'chips' this is always true.
    Make sense?
  9. kc5tpa
    Member
    Sep 21, 2012
    48
    So basically what we're saying is you've not powered or grounded your 4017.
  10. paulktreg
    Jun 2, 2008
    622
    124
    Black square pin 8 (VSS) on the 4017 to 0V. Black square pin 16 (VDD) on the 4017 to 9V. Have a look at the connection from pin 3 on the 555 to pin 14 on the 4017, it shouldn't be connected to 0V, remove that green wire link. There maybe other problems but correct them first and see how things go.
  11. kc5tpa
    Member
    Sep 21, 2012
    48
    Recheck Pins 16, 15, and 13 on the 4017
  12. (OCP)RoboCop
    Oct 27, 2012
    8
    Oh ok cool I think I am on board with you guys now, I am going to have a once over with the suggestions and corrections you guys have thrown out there and I will let you know
  13. donho
    May 16, 2010
    5
    The Polarity of the 1N4148 Diodes is not correct from what i see in the picture. They are 2 sets of common cathode. The ones on the right are definitely backwards, and 2 of the ones on the left are reversed.
  14. kc5tpa
    Member
    Sep 21, 2012
    48
    Good eye. The top and bottom (left set) diodes are reversed. As already stated all 3 are, on the right.
  15. (OCP)RoboCop
    Oct 27, 2012
    8
    Good looking out, you guys thought I was joking when I said I was a real novice didn't you? lol
  16. kc5tpa
    Member
    Sep 21, 2012
    48
    So, working or no? Or still having issues.
  17. (OCP)RoboCop
    Oct 27, 2012
    8
    Sorry for the delay been a little busy, so here is what I have done, I pretty much stripped the breadboard and started over from nothing and in the process I checked all the pins like everyone has told me and made the corrections as suggested I turned around all the diodes so the polarity is correct.
    I have one question though someone mentioned pin 13 on the 4017 mine is hooked to nothing what should I have that hooked up to?
    Here is a picture of my updated progress -
    So the bottom line is I have nothing now lol before I had a dim dim flicker now I have no light no flash, 0
  18. KJ6EAD
    Apr 30, 2011
    1,426
    363
    You don't have the 4017 enabled (pin 13 low). I didn't check for other errors.
    Clearly, you need a more methodical approach to converting what you see on the schematic to a breadboard. It may help to redraw the schematic using component models that display the pins in their correct relative positions or at least make sure all pins are numbered on the schematic. One technique that some of us use is to "check off" each component, jumper or node on a printed copy of the schematic with a highlighter marker or other colored pen as the corresponding part is installed on the breadboard.
  19. Audioguru
    Dec 20, 2007
    9,411
    896
    Most of us look at the datasheet of an IC or other part. The datasheet explains exactly how to use it.
    But some people translate the datasheet into their own language then the translation is A MESS.
  20. kc5tpa
    Member
    Sep 21, 2012
    48
    You now have two grounds on both chips. Pin 1 and Pin 8, not a problem, but not needed. Put the green jumper to GND & Pin 13.
    You're getting closer, can you turn the breadboard around and take a pic to see the power rails and those components.
