Hi all,
I'm having trouble with this circuit and need some insights. It's configured as an oscillator, but does not behave correctly under certain conditions. Power is applied to pin 8 (+12VDC) at all times. The circuit is activated by switch closure (actually a Darlington) which completes a ground loop to pin 1.
When a NE555P chip is installed in this circuit, it behaves normally. When pin 1 is grounded, the 555 immediately goes high (~10VDC) for ~0.5 secs and goes low for the time set per the 100K trimpot. This cycle repeats until the ground connection to pin 1 is removed.
When a MC1455 chip is installed and power applied, the pin 3 output immediately goes high (~10VDC) without pin 1 being grounded. When pin 1 is grounded, the 555 goes low for the time set per the 100K trimpot, and does not oscillate. When the time runs out, the pin 3 output again goes high.
The diodes in this circuit are both 1N4148's.
Does anyone have an idea as to why this is happening? All advice is appreciated. Thanks!
