Thank you for your input. One last question concernign timing. To make sure the safety timer U1 always starts when the output signal goes high, I should be able to move the trigger input to U1 to eye2 along with the pull up resistor. then add an inverter from eye 1 to feed pin 4 (reset) on U1. Would this make sure U1 is always reset and ready to start timing from zero when eye 2 is active?
Thanks again, you have been alot of help. any suggestions on where to purchase the cd series chips for reasonable price and delivery. No one around me carries them.
