Hello all, Hop someone can help me out here. I've been tasked by a friend to fix an issue for him. The solution I wont go into unless required, but it involves using a 555 in an astable circuit.
What I need to know is, upon power up, does the 555's output pin (3) start HI (even for a ms) and get pulled LO and stay LO until the first output pulse (at which point it would go HI). OR Does the output pin start LO on power up and only get pulled HI on the first pulse.
I know these two options are very similar, but for what I'm hacking this into, the output CANNOT go HI before the first timed output pulse (which is timed for about 3.5seconds). It MUST stay LO at all times before that first pulse.
Now naturally I'd assume that it says LO at all times until its pulsed HI. But whats causing my confusing here is that I've got the circuit in a simulation program (ISIS Pro). And with a load on the output pin (a BC108 switching in 12v to a relay), ISIS is clearly showing the output going HI for a split ms, this is long enough to cause the transistor to close, and the relay configuration to latch. I need the relays to latch AFTER the delay til the first pulse (3.5seconds).
With NO LOAD on the output pin, as in, just a bus wire, and a voltage probe on it in simulation, the output pin doesnt go HI on powerup and the fall LO until its pulsed. It stays LO at all times before the first pulse. So I'm now not sure if this is just a bug in the ismulation software, or wether this will actually happen if I build the circuit for real.
Can anyone clarify the characteristics of a 555 and its output pin??
Thanks all, Dave.
Thanks all, Dave.
