555 Timer help
Discussion in 'Homework Help' started by Chris15, May 10, 2009.
  1. Chris15
    Thread Starter Active Member
    Apr 15, 2009
    252
    Hi
    I want to make an electronic timer that will sound an alarm like for in the kitchen, i want it to run off 9V and range from 1min - 30min if possible. have a Pot for ajusting it and a start push button, thanks
    Chris
  2. mik3
    Feb 4, 2008
    4,846
    63
  3. bertus
    Administrator
    Apr 5, 2008
    15,802
    2,388
  4. mik3
    Feb 4, 2008
    4,846
    63
    Good point Bertus.
  5. Chris15
    Apr 15, 2009
    252
    hey thanks guys finally i find what i wnated, so if i replace the resistor with a 10M pot how will i know what time it is on do i set it wait and mark it?, and another thing what value shoud the capacitor, im thinking 1000uf
  6. Wendy
    Mar 24, 2008
    20,772
    2,540
    You need to calibrate it. Use something erasable at first, set it then see how long it goes for a random setting (or space them out regularly). You can extrapolate the settings after several points.
    Or you can use a DVM to set the resistor for a specific time setting, and put a mark there.
    Did you read this?
    555 Monostable
