555 timer help
Jsean21
Joined Jan 8, 2009
20
how can we divide the internal diagram into 3 main sections? its so confusing, please can someone help? thank you!
mik3
Joined Feb 4, 2008
4,843
Look at the three 5K resistors as a voltage divider. Then look at the two pink triangles which are comparators and they compare the voltage dropped by the voltage divider with input voltages. Finally, is the control stage (flip flop-F/F) and the output stage.
Jsean21
Joined Jan 8, 2009
20
oh ok, thank you, and sorry about the language, nvr meant to cause ne offence. i bear that in mind the next tym i post something.
