555 timer driven motor(info for Jure George)
Discussion in 'The Projects Forum' started by iONic, Jan 6, 2009.
  1. iONic
    Thread Starter AAC Fanatic!
    Nov 16, 2007
    1,422
    68
    Received a request by a new member "Jure George" requesting help with a modification to a circuit I posted. I have been talking to him via email, but wanted to make the circuit idea public here so that I don't go and cause him to buy parts he doesn't need, or to design a circuit that won't work. Here is the info for all to contemplate and aid in designing...
    See Circuit diagram below.
      File size:
      27.9 KB
      124
  2. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    There is no current limiting resistor on the base of the 3055 transistor. You'll fry the ICM7555 timer. Even at maximum voltage, it can only source about 10mA.
    The ICM7555 timer cannot source enough current to saturate a 3055 transistor. Replace it with a logic-level MOSFET, with a suitable resistor to limit gate charging current to 10mA max, and use a 10k pull-down resistor on the gate to keep it turned off in case of circuit failure. Add a flywheel diode across the motor.
    You have a 2A supply and a 5A fuse. Instead, you should be using a 2A slow-blow fuse.
    A 150uF electrolytic capacitor will probably have too much leakage current to be charged up via the 100k pot.
    If the 100k pot is set too low, it will get burned up due to the current flowing through it trying to charge the cap.
    A 7404 inverter is not necessary. Put a 10k pullup resistor on the ICM7555 pin 2, and use a 2N2222 NPN transistor with it's collector connected to pin 2, emitter to ground, and a 4.7k resistor to the signal input. When the signal input exceeds about 0.7v, the transistor will conduct, placing near 0v on pin 2.
  3. Audioguru
    Dec 20, 2007
    9,411
    896
    A weak but passing 2N3055 transistor needs a base current of 400mA (40 times more than the output current from an ICL7555) for a collector current of 4A.
    An ordinary 555 has a max ouput current of 100mA (10 times more than an ICL7555)when it has a supply as low as 5V and still won't drive many 2N3055 transistors.
  4. iONic
    Nov 16, 2007
    1,422
    68
    Attached is the best I can do tonight....
      File size:
      39.5 KB
      77
  5. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Go back to a CMOS timer. A bjt 555 will have too much of a voltage drop on it's Darlington output to get a logic-level MOSFET gate high enough (Vcc-1.3 to Vcc-1.7).
    Replace C1 with a 2.7uF poly cap (for low leakage).
    Replace R1 with a 5 MEG pot, and add a 100k fixed resistor either above or below it; in series with it. This will give a range of about 300mS to 15 seconds. Mouser carries 5M pots:
    http://www.mouser.com/Search/ProductDetail.aspx?qs=60Hxy/TM9vQyFpXQXEQufw==
    So does Digikey, but they're much more expensive for this particular item.
    Use a 470 Ohm resistor between the gate and the 555 pin 3 (timer output). In conjunction with the 10k pull-down resistor, about 95% of Vcc will be achieved on the MOSFET's gate. Since this is a manually-triggered, very low PRF circuit, the time the MOSFET spends in the linear region isn't that important, but even with the high resistance and 10mA limit to the gate current should be under 10uS.
    For the motor flywheel diode, a 1N5400 series could be used, cathode towards the supply voltage. A Schottky diode would be better, but axial-leaded Schottky's are getting a bit hard to find. However, Mouser has these in stock:
    http://mouser.com/Search/ProductDetail.aspx?qs=KFo7JewZbUFlhstWnyA22Q==
    2A 40V Schottky barrier diodes in a DO-41 axial package, easy to deal with. Pretty reasonable too, at $0.18/ea when you're just buying a few of 'em. Get some for spares.
    Datasheet is here: http://61.222.192.61/mccsemi/up_pdf/SR202-SR206(DO-41).PDF
    They'd be good for building a bridge rectifier if you wanted to build a power supply from discrete components.
  6. eblc1388
    Nov 28, 2008
    1,542
    102
    Why would it be better to use a Schottky diode instead of a normal power diode on a motor?
  7. iONic
    Nov 16, 2007
    1,422
    68
    Sgt. Am I still sleeping or is this a tyop? 300ms to 15minutes? Should it not be 300ms to 15seconds?
    Updated circuit bellow...
  8. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Standard rectifiers, like the 1N4000 or 1N5400 series, switch very slowly. This gives the reverse EMF voltage lots of time to build up to possibly high levels, which would blast the source terminal of the MOSFET. I'm assuming the motor is a brushed type, where commutator connections are made/broken thousands of times per second.
    If the current were very low, our OP could've used switching diodes, like 1N914 or 1N4148. These are hundreds of times faster than standard rectifiers.
    However, the 2A current would burn the switching diodes up in a heartbeat. Schottky diodes have both very low switching times, and much lower Vf than standard diodes. The latter is not very significant here, but the switching time is.
    Our OP could use a standard switching diode if they used a small ceramic capacitor across it; perhaps 220pF-1nF. This would slow the rise time of the reverse EMF pulse, buying time for the diode to conduct.
  9. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    You typo'ed "typo" ;)
    Yes, it's 15 seconds, not 15 minutes. I was distracted when I made the post.
    You need a 100k fixed resistor in series with R1. Otherwise, if our OP turns R1 to minimum resistance, they'll fry R1, the 555 timer, or both.
    If you're going to leave the 1N5400 series diode across M1, then add a 330pF ceramic cap across the diode.
    The Schottky diode I recommended doesn't need the 330pF cap.
  10. eblc1388
    Nov 28, 2008
    1,542
    102
    While a Schottky diode is fast in recovery, the diode in this case is not recovering. It is reversed biased all the time and start conducting when the motor inductive back emf becomes larger than its forward voltage.
    Whether it is switching slower in the forward direction is not known for sure but I would refer you to the following website in which the author took a test to measure how fast IN4xxx & Schottky diodes switches in both the forward and recovery conditions.
    Makes interesting reading.
    Diode Turn-on Time measurement
  11. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Yes, it is interesting reading. They switch on more quickly than I thought.
    But, note the "spike" when the 1N4005 and 1N4007 become forward biased. There was practically no visible spike in the 11DQ05 Schottky test.
    It's too bad he didn't perform the test actually using the test diodes as a clamp for a coil.
    Come to think about it though, in this particular application the MOSFET is going to take around 200nS-500nS to turn off, so the rise time should be fairly slow from that aspect - it's the commutator switching that will happen quickly.
    I feel that it would still be a good idea to use a small cap across the diode; as it would completely absorb that spike.
  12. iONic
    Nov 16, 2007
    1,422
    68
    Think I'll wait till the OP shows up and gives us his opinions.
  13. Jure George
    Dec 28, 2008
    51
    Hello I am the person who asked for help to modify this Circuit
    My needs are for a Timer Circuit to be triggered by a Positive 5v signal, run for a dialed in amount of time, from 1 to 15 Sec. max. It would run a small brushed D.C motor with max. of 2A but usually below 1A. The entire Circuit would run off of the main boats Battery, either 6v, 7.2v, 7.4v upto 12v. Also the circuit needs to be physically small in size to fit smaller boats OR submarines.
    Also I would like to use the 555 I.C and NO FETS please because Airflow cooling most times is not possible. I have used a 2N3904 or 2SC1815 in another circuit with a 555 I.C before but looking for more durability in a design.
    I wish I new how to post Circuit Drawings I have drawn on paper here for your thoughts and suggestions. I am OLD SCHOOL, paper pencil/pen ruler design and then bread board experimenting the circuit to see if works.
    Any help would be appreciated as I have some more circuit I am having trouble with also.
    Thanks Again to All,
    George
    Hope that helps you with what I need.
  14. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    If you want the minimum to be 1 second, then the 10k resistor in series with R1 needs to be increased to 330k.
    The MOSFET won't require cooling. A BJT (transistor) solution would require a Darlington configuration, which would require cooling.
