555 Timer Circuit, too slow to reset.
Status
Not open for further replies.
Markw996
Joined Dec 20, 2009
14
I have found a simple 555 Delay-On circuit on this website, I hope to use it to filter out a series of approx ten 0.5s pulses of 12v before the supply either turns off, or turns on and becomes a positive supply.
The problem is that the capacitor doesn't discharge fast enough, and so becomes fully charged after maybe 5 or 6 pulses causing the output to pulse for the remaining 4 or 5 pulses before becoming stable.
Could I add something to the circuit to make the capacitor discharge (completely) between pulses without affecting the delay period, or should I be looking at the problem from a different ange, i.e. a different circuit?
Thanks,
Mark.
praondevou
Joined Jul 9, 2011
2,942
1. It would be interesting to know what power supply this is and what's the time between the 0.5s pulses.
2. Does the voltage go to zero between the pulses?
3. What are the values for Ra and C?
Markw996
Joined Dec 20, 2009
14
1. The power supply is from my car, the pulses are caused by the 'bulb check' monitoring computer.
2. Yes it does drop to zero between pulses.
3. At the moment I am just testing the theory on my breadboard, the values are 470k and 4.7uF to give a 3 second ON delay.
SgtWookie
Joined Jul 17, 2007
22,230
From what you said in the post I quoted, this must be an automotive modification project which we do not support, in accordance with the Terms of Service paragraph 6.
bertus
Joined Apr 5, 2008
22,278
I am closing this thread as it violates AAC policy and/or safety issues.
Quote:
6. Restricted topics. The following topics are regularly raised however are considered “off-topic” at all times and will results in Your thread being closed without question:
  • Any kind of over-unity devices and systems
  • Automotive modifications
  • Devices designed to electrocute or shock another person
  • LEDs to mains
  • Phone jammers
  • Rail guns and high-energy projectile devices
  • Transformer-less power supplies
This comes from our Tos:
Terms of Service
There will be enough sites where automotive questions can be discussed :
Member selected automotive forums
Bertus
Status
