555 timer as an astable multivibrator?
Discussion in 'Homework Help' started by pfelectronicstech, Oct 11, 2012.
  1. pfelectronicstech
    Jan 18, 2012
    178
    I'm trying to calculate the duty cycle of a IC 555 as an astable multivibrator. The Ra is 18K ohms, the Rb is 68K ohms, C is 0.04 and I have come up with 0.56 and that is wrong. Any ideas?
  2. mlog
    Member
    Feb 11, 2012
    276
    36
    What equation are you using? I'd say you're wrong too.
    By the way, it's meaningless to say C=0.04. What are the units?
  3. JoeJester
    Apr 26, 2005
    3,393
    1,211
    Show your work for t1 and t2 ... then calculate the duty cycle
  4. pfelectronicstech
    Jan 18, 2012
    178
    Sorry its .04 microfarads, just forgot to add.
  5. Audioguru
    Dec 20, 2007
    9,411
    896
    The capacitor charges with 18k + 68k= 86k.
    The capacitor discharges with only 68k.
    So calculate the duty cycle.
  6. pfelectronicstech
    Jan 18, 2012
    178
    Oh, ok, thanks, I'm coming up with 69.4 now, am I correct, getting closer?
  7. mlog
    Member
    Feb 11, 2012
    276
    36
    Remember what Audioguru said? Discharge time divided by the sum of the charge and discharge times.
    D = \frac{R_b}{(R_a + R_b) + R_b}
    pfelectronicstech likes this.
  8. pfelectronicstech
    Jan 18, 2012
    178
    Finally, thank you mlog! Thank you, thank you, I just was not thinking about the problem in the right way. I tend VERY often to over think the situation, which is a bad trait. I suppose a lot of Techs over think situations though? Thanks again for the help.
  9. Ron H
    Apr 14, 2005
    7,050
    657
    Page 6 in the datasheet has this equation. Datasheets can be very handy.:)
  10. pfelectronicstech
    Jan 18, 2012
    178
    Thanks, I did not think to check the datasheet, my nose was stuck in my text books. Thanks again for that.
