The CMOS version of the 555 draws very little quiescent current, typically 65μA, maximum 200μA. Is it possible that you meant you measured .1mA instead of .1μA? My Fluke meter won't measure less than 1mA.Thanks a lot. It's working. Is there a way to measure current that the 555 timer take while waiting for trigger? It doesn't seem right (0.1uA). I want to calculate the battery life.
Can we discuss about design #2, using astable mode of 555 timer? My aim for this design is that, until the button is pressed, there's no battery loss to the circuit. Completely shut down circuit. That's why I connect the button to the gate of the mosfet, thinking that the button will trigger the first mosfet, then power the second mosfet and run the 555 timer. Like I said, I never use mosfet before, that's what I think it should work but obviously it's not and I have no idea why.
I have not studied design #2. but the simplest way to prevent any battery drain is to use an on/off switch for the entire circuit.
