But your schematic shows two LEDs in series and a resistor. Do you have one or two LEDs in series???Each LED is hardwired with the appropriate resistor for 4.5v
Maybe. The current will be higher when the voltage is higher so the 56 ohm resistor values must be increased to limit the current.Will I have to rewire the strands if I step up to 6v?
Yes. Adding another resistor in series with the 56 ohm resistors is the same as increasing the value of the 56 ohm resistors.or could I toss a resistor before the strand that will (when added with the already hardwired one) adjust for 6v?
