555 servo control gets hot
Discussion in 'General Electronics Chat' started by CTRL+X, Apr 4, 2015.
  1. CTRL+X
    Jul 1, 2009
    26
    So I am using this circuit to run a servo, the the pontentimeter replaced by an LDR. Trying to use it to control window blinds. Open when light, close when dark, ect...
    It seems to work fine, however the 555 chip gets too hot to touch very quickly.
    I ran it for about an hour, but not sure how long it will last being that hot.
    Any way to modify this circuit to mitigate the heat, or suggestions on a different circuit? I've seen people using an Arduino, but I don't currently have one.
  2. OBW0549
    Mar 2, 2015
    1,395
    941
    If you wired it up as shown and with the component values given, it shouldn't get hot at all. Check your wiring.
  3. Hypatia's Protege
    Distinguished Member
    Mar 1, 2015
    2,848
    1,317
    I concur with OBW0549
    Please double-check the circuit with special attention to R2, R3 and the power supply...
    Good luck and best regards:)
    HP
  4. MaxHeadRoom
    Jul 18, 2013
    10,851
    2,524
  5. CTRL+X
    Jul 1, 2009
    26
    Yep, that was it.... lol. I had an 82 ohm on R1 instead of 820, and somehow had completely overlooked R2. Corrected these, and it is no longer heating up, and seems to be functioning ok.
    It does seem to get a bit of chatter when the light intensity is changed quickly, however if it is facing out a window, it shouldn't have that issue.
    I'll also look into that other circuit as well.
    Thanks,
