Potato Pudding
- Joined Jun 11, 2010
- 688
PIC10F320 with specific reference to Numerically Controlled Oscillator.
Compare this to a 555 plus external resistors and caps.
And, to the degree that clock-to-Q delays are identical for rising and falling outputs.Agreed.
However, I got the impression from several things the OP said that he didn't want to have any pots or other adjustments in there. That's why I think he will be better served by an AMV running at twice the frequency followed by a frequency divider. He can focus his component selection on achieving the desired frequency without worrying about duty cycle, doesn't have to worry about loading effects or driver imbalance, and is guaranteed to have 50% duty cycle to the degree that the oscillator frequency is stable.
Initially i thought that by describing only the 555 part someone would come up with an answer but i think that this is a more complex problem.. Anyway, if my last post was out of subject i will repost it in a new thread.You've added some things that complicate matters (I think).
Frequency will not be linear with respect to capacitance. As noted by others, the period will be linear and so the frequency will be recipricol.
When you say accuracy is not important, accuracy of what? Frequency? Duty cycle?
If 50% duty cycle is important and it is important that it stay that way over varying conditions without adjustment, then I would definitely recommend using the frequency divider.
I already mentioned that:A 50% duty cycle square wave does not eliminate harmonics. It only eliminates even harmonics. Your first harmonic will be at 3 times the fundamental instead of 2 times, but the total harmonic energy is really a function of rise and fall times more that it is a function of duty cycle.
6) 50% duty cycle is important because otherwise i have even harmonic energy <> 0 (smaller bandwidth)
by Duane Benson
by Jake Hertz
