i am thinking 10M on each comp input.Unknown, it floats. If you add a 10Mohm to ground it will either go 100% or 0% if the wiper fails.
the two pots will be used on a regular basis. i will be using quality sealed pots, but i might as well protect against the possibility.....You could accomplish that at the pot, perhaps.
But I wouldn't bother until you analyze what the consequences are. I mean, if the comparator "scratching" from one state to another as you turn the pot is very bad, then by all means protect against that. But if the pot is rarely moved and a blip wouldn't do serious damage even if it happened, then there's not much incentive to protect against such a thing.
Wiring the "dead" leg of a pot is free, easy and good form. But it's far from a mandatory practice. It's just something you do because you have a choice, and there's a small reason to choose one side of that choice. I don't think most designs specifically address the type of intermittent pot failure we're talking about. My 2¢.
the - of comp might float due to the dpdt switch i have in there.The only input that needs the 10MΩ is the one connected to the wiper.
Here is another variation in Chapter 10...
ok, you are talking about the freq adjustment? i switched to 22u & 500ohm, this gets me into an acceptable range with 10mA as the surge as the cap charges and discharges. with 150ohm and 68u its pushing 33.3mA (well, it would if perhaps the supply was higher than 5v).Yep, I think the problem is the 150 ohms for the high speed. The CMOS 555 can't drive much. That's why the timing is ok when the 10K is in the circuit. I suspect you can see it change as you adjust the pot lower.
The 7555 and 7556 at low voltage have a definite drive problem, which is probably what you are running into. In other words, what Ronv said.
Try this design for the triangle generator instead...
It should just drop in, and does not depend on the power supply voltage in the slightest.
Or you could use 12VDC instead.
yikes..... i already stated why..... this module will be isolated from the machine. the opto side is doing exactly what i want it to do, which basically moves the wiper from one side to the other, which is exactly the same thing as cycling the mechanical pedal quickly with your foot.If this is for your Tig pulser, why not use the 12V output from the amphenol connector?
well, given the opto led isolation when using np fet between comp and opto, i no longer need 556.... a 555 or 7555 will do. i will try a 555 @ 12v to see if the freq ranges work any differently.Just for the halibut try 12 V and a regular 556.
Like I said, more than half the battle designing is knowing the limitations of your chips.
by Jake Hertz
by Jake Hertz
by Duane Benson
