555 PWM problem in PSpice
Discussion in 'General Electronics Chat' started by pan--, Aug 11, 2010.
  1. pan--
    Aug 11, 2010
    Hello I am trying to make a 555 timer PWM and connect it to a mosfet for a buck converter. My problem is that the PWM wont go down to zero.. also do you know how to make my duty cycle from 50% to 25%? This is my circuit:
  2. PRS
    Aug 24, 2008
    989
    35
    The usual way of using a 555 timer to create PWM is to use two. The first is an astable multivibrator which provides a square wave to drive the second 555 timer which is hooked up in the monostable mode. The mono varies the pulse length such that it can be used to vary the speed of a dc motor. Say the first stage creates a square wave with a PRR of 1 kHz, then the second stage is made such that it varies the on time from zero to 100 percent. The frequency of the first stage is under your control and you can calculate it, so too the pulse width of the second stage. Fixed capacitors are used in conjunction with variable resistors, but you can use fixed resistors with variable capacitors, too.
  3. Wendy
    Mar 24, 2008
    20,772
    2,540
    Actually you can use lots of ways for a 555, two timers will work but it isn't necessary.
    Is the 25% to 50% a firm number? You mentioned going to 0% PWM.
    LEDs, 555s, Flashers, and Light Chasers
    Chapter 5 The 555 and PWM
    Is that MOSFET a logic level type? If it isn't then a 7404 won't cut it for driving the MOSFET. A CMOS 555 will do a much better job overall, and a standard 555 will work better than a 7404. The real problem is you need more than a 10V power supply if it is a standard MOSFET.
  4. Ghar
    Mar 8, 2010
    655
    72
  5. Potato Pudding
    Jun 11, 2010
    684
    92
    You don't want to go to 0% PW very often because the inductors will ring. If you shoot too narrow a pulse of current into a coil it causes a higher proportion of noisy inefficient and often destructive resonance. Inductive motors have similar issues. It also depends on frequency and the coil (Lower frequencies and lower inductances tolerate lower %) but below about 2 to 10% PW you might use other methods like pulse blanking or other frequency reductions to reduce the output.
    If you were using 400 Hz and .1uH then you probably can go to .1%, but if you had 1H and 400kHz then you might have to stick to nearly 50%.
  6. pan--
    Aug 11, 2010
    Thanks everyone for your help. Do you know also why when I change the value of resistance R7 the output voltage will change as well? I mean.. an increase of R7 will cause a decrease of the output voltage. Do you know how can I explain that?
  7. Potato Pudding
    Jun 11, 2010
    684
    92
    Increase of R7 causes a decrease in Output Voltage?
    R7 is a pull up resistor for the gate of the FET. If the resistor is larger then your obsolete 7401 NAND open collector output gate will sink all the current from R7 more easily but the gate charge will not get high enough quick enough. Your RC time for R7 with the FET gate being the C, will get too long.
  8. bertus
    Administrator
    Apr 5, 2008
    15,796
    2,384
    Also R6 at the output of the 555 is not needed, or at least the value can be much higher.
    Bertus
  9. pan--
    Aug 11, 2010
    ok thank you very much also.. please see the image below.. Do you know why the duty cycle makes that knee and its not rectangular like it should using the nand gate? I believe it has to do with the mosfet or something and the current but I am not quite sure.
    Thanks again for the previous answer
    http://www.mypicx.com/uploadimg/42865842_08282010_1.jpg
    The green line is after the nand gate
  10. Potato Pudding
    Jun 11, 2010
    684
    92
    Looks like a capacitance charging curve. Is that with the larger value R7 because that could be the gate charging?
    I am surprised that it says that you will get that close to the rail when the gate drive is from the rail.
    The IRF150 is rated for 2 to 4 Volts threshold I think.
  11. Wendy
    Mar 24, 2008
    20,772
    2,540
    A side comment, a 7400 series quad NAND gate is not meant to drive a MOSFET, ever. What prompted you to select this device?
  12. Potato Pudding
    Jun 11, 2010
    684
    92
    I assume that he is in the same class as Vultac who also wanted to use the same type of NAND for his switcher project.
    Almost identical projects and they started with similar parts.
