I am wondering which is more effective. The circuit would use 1 pot to change a pulse from 1hz to (60-120hz). The circuits I have built require a large range to be able to do this. An example is it takes 1/2 turn of the pot to go from 1hz to 1.5hz then 1/4 of the turn to go from 1.5hz to 20hz and the remainder from 20 to 60 quite rapidly. Outside of using a pic to register the pot and change the value accordingly can this be done?
