555 one-shot latch
Discussion in 'General Electronics Chat' started by eyesee, Oct 19, 2013.
  1. eyesee
    Oct 19, 2013
    33
    I'm trying to design a monostable timer circuit that will not re-trigger at all. I know the HC221/HCT221 non-triggerable monostable ICs prevent a re-trigger during the monostable period but doesn't prevent a re-trigger after the monostable period has elapsed.
    I was wondering if I could somehow implement this function with a 555 alone or whether I'd need to also incorporate a latching circuit?
    Thanks.
  2. elec_mech
    Nov 12, 2008
    1,513
    193
    We need more information. What will trigger the circuit? You could use an edge-trigger, but this only prevents the monostable from re-triggering if the signal is held low. Example, if your circuit is triggered with a latching switch, the monostable will trigger when the switch is initially latched, but it will not re-trigger until the switch is un-latched and re-latched. In the case of a momentary switch, if someone presses it, the circuit will trigger but will not re-trigger until the switch is released and pressed again.
    If you want the circuit to trigger one time only, how will you reset the circuit?
    Another thought is to add a power-on trigger (see link above) so instead of using a switch, the 555 triggers when power is first applied and stays off until you cycle power to the circuit.
  3. eyesee
    Oct 19, 2013
    33
    The trigger input will be a photocell or a couple of bare wires to sense moisture. Can a 555 directly trigger on either of these?
    The circuit will be reset by switching it off and back on again.
  4. Alec_t
    Sep 17, 2013
    5,976
    1,136
    A latching circuit should do it.
    What is the monostable pulse width and how accurate does it need to be?
  5. #12
    Nov 30, 2010
    16,704
    7,351
    Last week I told somebody to hold the reset pin (4) to ground to force an off and The RB told me that collapsing the voltage on pin 5 will have the same result. I'm thinking, SCR. Won't work on "reset" because it won't go as low as .7 volts, but it might wok on pin 5.
  6. ErnieM
    Apr 24, 2011
    7,438
    1,626
    AFAIK the 555 does not retrigger.
    As long as the starting trigger is gone by the timeout time you are fine, but THAT condition is not met by the type of sensors you have mentioned.
  7. eyesee
    Oct 19, 2013
    33
    The duration of the monostable needs to be around a minute or so. Doesn't need to be hugely accurate.
    The trigger may be continuous or occur again however, the monostable should just operate once and only reset when power is cycled.
    Can SCRs operate from 1.5V? If not, what type of latch would operate on such a low voltage?
  8. #12
    Nov 30, 2010
    16,704
    7,351
    If you can't buy one, you can make one.
  9. mbohuntr
    Apr 6, 2009
    413
    32
    Darn it #12, you beat me to it!!! :D
    #12 likes this.
  10. #12
    Nov 30, 2010
    16,704
    7,351
    Some of us type with TWO fingers.:D
  11. eyesee
    Oct 19, 2013
    33
    I'm guessing most NAND ICs operate at around 5V to make an S-R latch?
  12. Alec_t
    Sep 17, 2013
    5,976
    1,136
    CD4011 or CD4093 NANDs will operate at 3V - 15V.
