555 Monostable times out...
Discussion in 'The Projects Forum' started by mark.w, Oct 16, 2013.
Thread Status:
Not open for further replies.
  1. mark.w
    Oct 16, 2013
    Please can somebody advise for the following problem.
    I'm fitting a 555 Monostable cct into my car so that it triggers upon locking to give me 5 seconds of delay. It all works fine....lock car, cct triggers the 555....it operates relays and gives power to the car's circuits I want.
    However, if the battery voltage drops to about 12.3v the timer triggers ok but does not reach the point where it would normally drop out.
    I've measured the rising voltage on pin 6, the 555's threshold pin, and it doesn't get past about 8v when in this fault condition.
    I'm using this circuit (http://www.maplin.co.uk/media/pdfs/N32FL.pdf) but have replaced the original timing electrolytic capacitor (1000uF) with a 10uF to make the adjustment range more suitable. It was 1sec to 15mins......it's now virtually 0 secs to 11 secs. The timing components are 1x1k resistor@1x1M pot & 1x10uF Electrolytic.
    The on board relay has been 'turned around' (electrically) so that the 555 is sourcing the load not sinking it too, as that would place unnacceptable drain on the battery.
    As I say it all works fine until car battery voltage approaches 12.3 v and then it won't get out of triggered mode......
  2. bertus
    Administrator
    Apr 5, 2008
    15,796
    2,382
    I am closing this thread as it violates AAC policy and/or safety issues.
    Quote:
    6. Restricted topics.
    The following topics are regularly raised however are considered “off-topic” at all times and will results in Your thread being closed without question:
    • Any kind of over-unity devices and systems
    • Automotive modifications
    • Devices designed to electrocute or shock another person
    • LEDs to mains
    • Phone jammers
    • Rail guns and high-energy projectile devices
    • Transformer-less power supplies
    This comes from our Tos:
    Terms of Service
    There will be enough sites where automotive questions can be discussed :
    Member selected automotive forums
    Bertus
Thread Status:
