555 monostable multi vabrator
Discussion in 'The Projects Forum' started by mbasile35, Jan 21, 2013.
  1. mbasile35
    Nov 2, 2011
    23
    Hey everyone
    Im desinging a ciruit that will control twp relays when power is applied to the circuit. I've done a little research and I think a monostable multivibrator circuit should work for me. If I understand corretly as soon as the circuit sees an input voltage, the 555 can turn on a relay that would hold for a certain amount of time? Even if my input stays contantly on?
    Mike
  2. wayneh
    Sep 9, 2010
    12,377
    3,231
    Yes, that's true. But I recommend sketching out your idea into a schematic for review. Worth a thousand words.
  3. mbasile35
    Nov 2, 2011
    23
    Ok here's the schematic. I through it together pretty quick but here it goes. The input is tied directly to ground because i want the trigger to be the board actually getting power.
    I based the circuit on this page I selected the values of C4 and R1 based on the equation on that site so get a 1 second timing period.
    Does this seem like its going to work?
    Thanks again
    Mike
