555 lamp dimmer
Discussion in 'The Projects Forum' started by capacitivedischarge, Dec 8, 2009.
  1. capacitivedischarge
    Dec 8, 2009
    Hello all,
    I am doing an electrical engineering project and I seem to be stuck on a few points. What I need to know is the limits of the below lamp dimmer project/555 timer and how it may be improved. Any insight would be more then appreciated.
  2. MikeML
    Oct 2, 2009
    5,451
    1,066
    A standard 555 can only switch a load that draws <200mA. Any lamp you are likely to grab will draw more like 1A, so you will need to add a transistor/FET switch between pin 3 and the lamp.
