Hi Guys
Can anyone help me with my question?
Im trying to make a circuit with a 555 timer that will allow me to press a momentary push to make button and then latch the output (which i have managed to do).
However I also need to the circuit to be able to switch off an output using a relay or similar when either a external -ve or +ve is detected using the same on/off switch.
I have attached a basic circuit below as to what i i have done so far.
Can any of you guys help me?
