555 Circuit Peculiarities
Discussion in 'General Electronics Chat' started by damnyankee36, Mar 9, 2016.
  1. damnyankee36
    Dec 19, 2015
    8
    I am using a 555 chip for a monostable time delay circuit. I am using a trimmer to adjust the delay, which is around 10 mS -200 mS. It works quite well at the longer delays and within tolerable limits the lower I adjust it. However, when I get below 20 mS, the delay occasionally swings down 10 mS or more. It happens every 5-20 triggers, very random.
    The circuit is below. I am using a relay to power and trigger the 555 simultaneously at the + and – inputs with a regulated 12v. Could contact bounce be the cause? The relay is producing about 5 mS worth of bounce. I’m also wondering; when does the 555 decide to recognize the input, at the beginning of the bounce pulses or at the last one? I am also using .01uF cap at terminal 5 for possible noise control.
    I am using 2.2 uF and 4k values for the 10 mS setting.
  2. k7elp60
    Nov 4, 2008
    479
    69
    The problem may be the relay as they have an operate and release time.
  3. Alec_t
    Sep 17, 2013
    5,973
    1,135
    Pins 4 and 5 of the 555 are floating. Interference picked up on those pins might be causing erratic triggering/timing.
    Why are you using this rather unconventional triggering method involving switching both power rails of the 555?
  4. Dodgydave
    Jun 22, 2012
    5,154
    772
    Is pin 4 connected to pin8, as its not showing on your drawing...also i would put a 100uF capacitor across pins 1,8
  5. ian field
    Distinguished Member
    Oct 27, 2012
    4,447
    791
    The appnote suggests a 10nF from pin 5 to GND - but I've seen a few people get away with not bothering.
  6. AnalogKid
    Aug 1, 2013
    4,696
    1,297
    That would be me. In the original 555 the three resistors that set up the two comparators were 5K each, so the circuit impedance at the control input is less than 5K. A little noise here does affect the circuit timing, but not greatly. If the application can stand a 5% variation in timing, I skip the noise filter cap.10 cents is 10 cents.
    ak
  7. damnyankee36
    Dec 19, 2015
    8
    Thanks for all your suggestions! This is my first attempt at using a 555. So I was totally dependent on finding a circuit that was already proven.
    Because the diagram didn't show it, I mentioned in my post that I used a .01 uF on pin 5. I should have informed you all that I found this elsewhere and used it because it did what I wanted. I needed it to sink the load, not supply it as most diagrams show.
    Would I put another cap on pin 4? What size?
    I think I am following you. Are you saying I should have it already powered before I trigger it? Not sure how I would do that...
    I connected both those pins together and didn't notice any difference on the scope. However, when I placed the cap across 1 and 8, the input and output timing went all to hell!
  8. damnyankee36
    Dec 19, 2015
    8
    So, I just used the micro switch that was previously triggering the input relay. The switch by itself without the relay was much cleaner and made the <20mS much more consistent. Now I am looking at a simple debounce circuit with an RC circuit since the final design has to include the input relay. Looked at solid state relays but DIP ones are only powered with 1.2v. I need to keep the relay coil side of the circuit at 24-30 volts.
    I only have so much room for the PC board. I need to keep the component numbers down and relatively small.
  9. Alec_t
    Sep 17, 2013
    5,973
    1,135
    Google '555 monostable' for examples of circuits using pin 4 as the trigger input.
  10. damnyankee36
    Dec 19, 2015
    8
    I've been doing a lot of searching on 555's with phrases that included your suggestion. It seemed like everything I saw had the output sourcing the load instead of sinking it. I wasn't concerned with the rest of the circuit at that time. I'll give it another shot.
    Thanks!
  11. ian field
    Oct 27, 2012
    4,447
    791
    You have a trig input to switch the output on, a threshold pin to switch the output off and a reset pin to disable the whole chip.
  12. Alec_t
    Sep 17, 2013
    5,973
    1,135
    Simple enough to change that: one end of the load to pin3, the other end to V+.
  13. damnyankee36
    Dec 19, 2015
    8
    That's what I tried to do early on. But it the waveform changed as shown below. I figured the the entire circuit has to be modified, not just switch the load connections.
  14. Dodgydave
    Jun 22, 2012
    5,154
    772
    What is it you're trying to do, fire a relay after a delay, or a delay first then fire it?
  15. damnyankee36
    Dec 19, 2015
    8
    Actually the way you're asking, both!
    After a specified delay, the relay fires and stays on.
  16. Dodgydave
    Jun 22, 2012
    5,154
    772
    So power on, delay, then relay fires and stays on till power removed,
    The circuit you have will do that, as well as this one, omit Q1, R2, and connect the relay to pin 3,..
  17. Alec_t
    Sep 17, 2013
    5,973
    1,135
    This should do it:
  18. ian field
    Oct 27, 2012
    4,447
    791
    The bipolar 555 can source or sink 200mA - I'm not up to date with the CMOS version, but I know the current capability is less.
  19. damnyankee36
    Dec 19, 2015
    8
    Thanks guys, I'll give it a shot. I can see why this can be so confusing; it seems like you can the same function in more than than one way!
  20. Alec_t
    Sep 17, 2013
    5,973
    1,135
    That's true of most electronics projects ;).
