555 circuit confusion
Discussion in 'General Electronics Chat' started by xxxyyyba, May 16, 2016.
  1. xxxyyyba
    Aug 7, 2012
    249
    Here is block diagram of 555 timer:
    I wouldn't analyse it, but under some circumstances (for some voltages at THRESH and TRIG pins), complemented output Q will be at high voltage level, with respect to ground (pin 1). And that's problem. For BJT to conduct, VBE is aprox. 0.7V, but in this case it will be much higher than 0.7V. What would happen in this case?
  2. Alec_t
    Sep 17, 2013
    5,977
    1,136
    Your diagram only illustrates the principle of operation and isn't intended to be an accurate portrayal of the inner workings of the IC. The not-Q output in practice would provide limited base current to avoid stressing the Vbe junction of the discharge transistor.
    xxxyyyba likes this.
  3. wayneh
    Sep 9, 2010
    12,391
    3,246
    The discharge pin 7 gives a path to ground. Current sinking is limited by the power dissipation rating of the particular 555 IC you are using. 200mA is typical.
    Or perhaps you were asking about the base current, which Alec_t has answered.
  4. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
    In real there is a resistor on the base:
    This is taken from the SGS datasheet.
    Bertus
    Sinus23 likes this.
  5. xxxyyyba
    Aug 7, 2012
    249
    Hello, thanks for replies. It's clear :)
