555 Bistable Random Power-Up State
apqo1
Joined Oct 5, 2008
52
I'm working on a bistable latch circuit to switch a MOSFET on/off with a momentary push-button switch. I've experimented with every BJT and FET-based "soft latch" circuit I can find; some don't work at all and others are intermittent or difficult to debounce.
I finally settled on the attached 555-based circuit. It works beautifully while powered, and I can't make it misbehave no matter how hard I try to bounce the switch. However, there's one problem: it sometimes starts in the "on" state when power is applied.
I've tried increasing decoupling cap C2 to as high as 220μF. This improves it a little, but if power is removed for more than ~15 seconds, it will still sometimes start up in the "on" state.
How do I guarantee that the circuit starts in the "off" state when power is applied, regardless of how long it's been removed?
Thanks.
apqo1
Joined Oct 5, 2008
52
Well, duh! Thanks, #12.
The 555 datasheet says RESET voltage is 0.7V typical. I put 1MΩ/0.1μF on RESET for ~5 millisecond delay reaching 0.7V at power-up.
Works perfectly! New schematic attached.
EDIT 1: Substituted 100kΩ/1μF to achieve the same RESET delay with parts already used elsewhere in the circuit.
EDIT 2: Added scope capture of the result. CH1 (
yellow) is Vin; CH2 (blue) is RESET. Nice to see the math work perfectly: 0.7V in 5.2 msec.
