Anyone have any links to a schematic that allows for a 555 (or 556) based controller that can drive a 36V/100W LED with alternating flash rates?
Here's where I'm looking to go eventually:
1. Strobe circuit allowing for 36v in and 36v out, DC.
2. Pulse rate flips from 9hz to 15hz every second.
3. Support for up to 4A
4. Latch timer. Trim pot to adjust "on" timer from 1 second to 10 seconds.
5. Heat not an issue. Unit will not be run for excessive cycles.
6. Fit in to smallest RS style project box.
7. Running from (6) 6V batteries so V regulation for sensitive lamps might be an issue.
