555-based button-press simulator circuit
Discussion in 'The Projects Forum' started by JimHung, Apr 22, 2013.
  1. JimHung
    Apr 21, 2013
    Hey everyone,
    I'd like to design a simple circuit that will emulate a physical button-press on an off-the-shelf toy voice recorder. My goal is to turn a little 10-second recordable voice module into a tailor-made (and re-recordable) annoy-a-tron.
    Here's the module that I have lying around: http://www.amazon.com/Message-Recor...06582&sr=8-2&keywords=recordable+voice+module
    There is a little conductive pad push-to-make switch that is used to trigger the sound or hold to record a new sample.
    My idea is to automate the sound playing by using a transistor as a switch to mimic the press of the button.
    So here's my issue - I'm trying to figure out what is the best design for the delay timer which will a) be able to be in the "off" state for a number of minutes, and b) be "on" for a similar period of time to a natural human press (I'm guessing about 1/3-1/2 a second?).
    After doing some research into ways I can pull this off, I found a few websites suggesting a 555 as an astable oscillator - this one in particular caught my eye: http://www.electronics-tutorials.ws/waveforms/555_oscillator.html
    The "Improved 555 Oscillator Duty Cycle" in particular seems like it fits the bill. I'm just having problems understanding how to select the right resistor/capacitor values that would give me an on/off cycle of something like 0.5s/420s (7 mins). There are a few calculators floating around, but they seem to expect you to know what R/C values you want to try - I haven't got a clue where to even start. Also, none seem to reflect the circuit in the link with the diode jumping R2.
    If anyone can give me some advice, I'd really appreciate it.
    Thanks in advance!
    Jim
  2. Dodgydave
    Jun 22, 2012
    5,154
    772
  3. JimHung
    Apr 21, 2013
    This looks like PRECISELY what I was after!
    I've just done the math and I'm comfortable I can switch up the numbers to make any reasonable delay I want - this is really great, much appreciated.
    Out of interest, is there any particular reason you chose such a cap? I'm assuming the line of thinking is that you'd pick a roughly reasonable sounding cap size and then do the calculation to find the required resistance, using the closest resistor you have - and if the required resistor is a ridiculous value, change the cap and try again?
    Thanks again for the help,
    Jim
  4. JimHung
    Apr 21, 2013
    Hey - just wanted to post a quick update to again say thanks, the project turned out really well and your suggestion works great.
    Here's a picture of the final product.
    Jim
