555 astable
Discussion in 'Homework Help' started by Viktor Vaughn, May 2, 2015.
  1. Viktor Vaughn
    Mar 21, 2015
    24
    Hi everyone,
    I am stuck on the highlighted problem 14.12. It wants me to use a 555 in astable mode with an inverter to produce a pulse generator for the listed variable frequency ranges. The problem is I dont know where to start, and this text book is very bad when it comes to examples and explanation. if anyone can give me clear instructions how to solve this problem, would be strongly appreciated.
  2. #12
    Nov 30, 2010
    16,704
    7,351
  3. ScottWang
    Aug 23, 2012
    4,933
    777
    Next time, if you have any questions, please attach the clearly pictures and using compression software to compress to a appropriate size, thanks.
  4. WBahn
    Mar 31, 2012
    18,087
    4,917
    Once you have an astable oscillator working (don't worry about what frequency or being able to change the frequency ranges, just get an oscillator working at any reasonable frequency, say something in the 1 kHz range), what can you do to set the duty cycle? What can you do to change the frequency (using a fixed capacitor value)? How does changing the frequency change the duty cycle?
