I could say "yes" but that leaves open the question "what" and "why" is bit banging done.i see..have you tried bit banging in a pic??
OK, so it seems you ordered a RTC... they are not the worst thing to integrate into your app. MC has several software libraries to use them (perhaps too many!).Thank you very much for your suggestions! i really appreciate it! ok then ill give it a try with the RTC..i was already planning to use it but my teacher said that it is hard to integrate this rtc with the mcu?? so i decided to use a simple 555 timer..i was not so familiar with RTC so i dont have any idea..what i knew was the built in clock inside the mcu,but it is very hard to configure..so ill give it a try with the RTC..thanks for suggestiions! Appreciate much! ill update again soon.
Do you have a coin battery to supply power to the DS1307 while external power is removed connected properly?I've used the DS1307..actually i've been able to display the time of rtc in an lcd..the problem is,it's displaying the time on my pc when i use my pickit2 in supplying voltage but when i use a separate voltage supply, it does not display any time and date..it seems like the time on my rtc was synchronized with the time in my pc..hope you could help me..thanks.
