Hi guys. I am wanting to power a speaker with 2 astable timers. I want the first timer to occilate slowly at about 3Hz, and the second timer to be at 50-100Hz. Pretty much it will be an alarm/buzzer. I've tested it and it works fine, but the only problem is that when I first apply power to it the first timer's first ocillation lasts longer than than its other ocillations. I know the reason it does this and it's because the capacitor has to start charging from 0 volts to 2/3Vcc(When first powered on) instead of 1/3Vcc-2/3Vcc so basically the first occilation is 2 times longer. Anyway, the point is that I want my alarm to be consistent so is there anyway I can make the first oxcilation consistent with the rest?
