555 as Toggle Switch
Discussion in 'General Electronics Chat' started by shahtiaz, May 31, 2012.
  1. shahtiaz
    May 30, 2012
    Dear Lubnan!
    can you send me the picture of your final toggle switch... where you have applied 10K resistor with 100uf Capacitor...
    I tried the same but didn't workout for me...
    please help...
  2. shahtiaz
    May 30, 2012
    Please provide me the picture of this toggle switch... this not working for me :(
  3. absf
    Dec 29, 2010
    1,493
    374
    Should be something like this...
  4. Wendy
    Mar 24, 2008
    20,772
    2,540
    Welcome to AAC!
    A thread belongs to the OP (original poster). Trying to take over someone elses thread is called hijacking, which is not allowed at All About Circuits. I have therefore given you a thread of your very own.
    This was split from 555 Toggle switch problem.
    I helped design a very similar circuit. What are you having problem with?
    555 Bistable Multivibrator
  5. Wendy
    Mar 24, 2008
    20,772
    2,540
    Much as I hate to disagree, that will not work. The larger capacitance will swamp the smaller, and the smaller capacitor is the "memory" of the circuit.
  6. absf
    Dec 29, 2010
    1,493
    374
    Agreed. So the value of 10uF capacitor has to be smaller than C1, right?
    Allen
  7. Wendy
    Mar 24, 2008
    20,772
    2,540
    No, eliminate the 10µF entirely, not needed or wanted. You will get greater benefit if the power supply Vcc is filtered.
    Same thing with the parts on pin 4, Pin 4 just needs to go to Vcc, nothing more.
    No, I'll take it back about pin 4, it makes the 555 assume a definite start up condition. You can do the same thing with a really small cap on pins 2 & 6 which could go to either Vcc or ground. It is an either or, not both.
  8. Ron H
    Apr 14, 2005
    7,050
    657
    I recall a thread from a few months(?) back, where the OP was going nuts with false triggering. IIRC, I recommended a small cap on pins 2&6. That node was apparently picking up EMI from the relay switching. I think the cap was about 10% of the memory cap.
  9. Wendy
    Mar 24, 2008
    20,772
    2,540
    I can believe it, but it also selects the power up state of the toggle.
  10. Ron H
    Apr 14, 2005
    7,050
    657
    Unless you also use a power on reset RC on pin 4, and make the reset time constant longer than that at pins 2 & 6.
